85 VF700F Rear Cylinders Cam Install
Discussion in 'Mechanics Garage' started by crazyjimmy, May 29, 2013.
  1. crazyjimmy
    crazyjimmy New Member
    I am frustrated. Installed new rocker arm on #1 Cylinder (Exhaust). Only removed exhaust cam. Re-installed exhaust cam for 1-3. All index marks/cast marks align. When I bring #1 up to compression cycle/finger on plug hole, the cam marks are upside down. And lobes for #1 are upright. Is this correct for valve adjustment or am I missing something? I cant be 180 out as all factory marks are aligned. My understanding is the lobes are opposite each other on 1-3 sides when at TDC. Any advice would help keep me from going CRAZY! Thanks in advance Guru's. Please help.:mad:
  2. crazyjimmy
    Anyone want to help? 1st timer needs it. I don't want to burn this engine up/push a valve(s) through piston.
  3. crazyjimmy
    Could I possibly have installed cam at #3 TDC? 14 Lookie Loos, No response.
  4. rjgti
    rjgti New Member
    regina sk
    so you say when you bring up on compression for #1 the lobes for that cyc are facinging up, will be normal, next to open will be exhust valves but make sure you are on compression for #1
  5. crazyjimmy
    Okay, I installed the cam with all cast marks/sprocket lines aligned @ T 1-3. When I turn alternator 360deg. to T1-3 I am at compression stroke and lobes on #1 face up and cast marks on cams face down. Is this correct and is this where I commence valve lash adjustment?
  6. rjgti
    rjgti New Member
    regina sk
    if both intake and exhust are straight up on compression then no. anyone have spec on cam lobes for me, I need degrees on cam lobes
  7. rjgti
    rjgti New Member
    regina sk
    I do not have cam specs on the 700?
  8. crazyjimmy
    According to dave dodge, the cam lobes face away from each other @ TDC. Mine are face up. Am I at #3 TDC? This is a friends bike and I don't want to F this up. Anyone know the right configuration? I followed the FAC manual. But hey, I'm falllable. Just human curiosity. Help if u know what's up.
