85 Vfr750 Gears Slipping And Grinding - esp 4th.
Discussion in 'Mechanics Garage' started by FstaRocka, Nov 22, 2014.
  1. FstaRocka
    FstaRocka New Member
    Cape town, Seattle
    Hi all. Just read thru this article and it sounds allot like my problem
    http://www.vfrdiscussion.com/forum/index.php/topic/72644-4th-gen-clutch-issues/page-6
    When i goto 3rd it starts slipping in and out of gear making a grinding noise.. 1,2,6 are OK.. With 1 and 2 perfect.. 4th and 5th seems worst
    When the bike idles and i lean it left and. Right the noise changes to a light rattle inside as the bike tilts...
    I have a spare motor, will be first time crackinga trans issue in many yrs.
    Any ideas?
    One mech said sometimes the trans wears into the cover and i should shim it or something.
    Do i have to drop motor to split case?
    Tx
    Also - the clutch seems to work fine, I can change gears really well at the mo - no "late/early" grabbing indicating the plates are still A ok i hope
    Bent or worn shift fork ??
  3. TOE CUTTER
    It sure sounds like the shift forks and gears are smoked. No sugar coating the task at hand.
