86 500 issues :(
Discussion in '1st & 2nd Generation 1983-1989' started by xxxbrandonxxx, Aug 27, 2009.
  1. xxxbrandonxxx
    xxxbrandonxxx New Member
    Burlington
    So i had my carbs air filter and plugs done this weekend, I got the bike back and noticed a small leak in the float bowl so i tightened up the screws and then started the bike
    It ran great, for about two days, so as i ripped it in 2nd gear i think, i heard my bike bog down, I get to the lights and realize i lost tons of power while in gear.
    he started it up and said your running on 4 cylinders after reving it, I have spark in all four cylinders and the carbs were just replaced (old ones were done)
    Could the problem be rust from my gas tank?(because i did have rust and my old carbs had two inline filters to the carbs) or something with a slider being lazy or sticking cuz there new?
    Could it be anything else? please help
  2. volks6000
    volks6000 New Member
    Jacksonville , Florida
    run cleaner and change out fuel filter see what that does.
  3. xxxbrandonxxx
    Burlington
    cleaner as in seafoam?
  4. squirrelman
    IF.you.had.rust.in.the.carbs.but.failed.to.clean&coat.tank.......there's.your.problem.
    you.can't.trust.any.filer.to.trap.all.rust.flakes
    a.rusty.tank.needs.this:
    "fueltanksealer" from www.caswellplating.com
  5. xxxbrandonxxx
    Burlington
    it wouldnt be a valve spring? cuz i was going in the higher rpms a couple times right when it happened
    And i never cleaned nor fixed the tank, never even thought about it seriously(newbie bike owner) even tho i could hear the rust flakes when i emptied my gas tank
  6. xtravbx
    xtravbx New Member
    Cleveland, OH
    Well if you could HEAR the rust in the tank, then you already answered your problem.
    Start simple - you know what could be causing a problem - so address that first.
  7. xxxbrandonxxx
    Burlington
    so then i should treat the tank which ive researched and know how then what? get the carbs re cleaned? would they need the float levels done and re syncing ?
  8. squirrelman
    carbs.still.ok.most.likely....synch.and.floats.won't.have.changed
  9. jporter12
    jporter12 New Member
    Johnstown, Ohio
    Even IF the rust in the tank isn't your current problem, it IS a big issue that needs addressed, and COULD be causing your problem.
    Take care of the tank, then if it's not right, you may want to pull the carbs again, at least drop the bowls, to see if any rust has clogged anything up.
  10. xxxbrandonxxx
    Burlington
    i cant see it being anything else? like i said all 4 plugs spark and run, just the 2nd cylinder isnt working :S
  11. jporter12
    Johnstown, Ohio
    If only 1 cylinder isn't running, it could still be a lack of fuel to that carb. Due to a chunk of rust? Other than that, it's time to get out a compression gauge!
  12. xxxbrandonxxx
    Burlington
    will i be doing harm by riding my bike like this for now till the shop can see it? i dont rip it just 5000 rpms then shift(even though it wont let me get over 7000 rpms on avg when I did first try)
