86/87 fairing lower connectors
Discussion in '1st & 2nd Generation 1983-1989' started by artee, Nov 8, 2013.
  1. artee
    artee New Member
    Rochdale,
    Hi
    I need to source two of these lower connectors.
    I did have all four but I have misplaced two from the right hand side.
    Can any one help
    Roger
  2. fredsncoma
    fredsncoma New Member
    Gardnerville, Nevada, United States
    Those two are the only I have ever had on mine as long as your riveted metal pieces are in place on the right hand lower it should be fine the clips hold both sides together
  3. fredsncoma
    Here is a pic of mine on the bike [​IMG]
  4. fredsncoma
    No comments from you, Toe on the condition of those brackets or the dirt on the inside of the fairing
  5. V4toTour
    V4toTour New Member
    If it was me, I'd just make some new ones. They're the same as the left side ones, just flipped around. go down to the local hardware store and pick up some galvanized flat stock. If the sheet selection is too thin, there are probably some brackets in the roofing section you could cut chunks out of. Using the ones you have, trace out a template accounting for the bent over tab as if it were unfolded. Cut off wheel, a vise, pliers, dead blow, drill. Should be ready to go in no time.
  6. squirrelman
    You can tie the 2 sides together using zipties or twisted wire.
  7. experience780
    experience780 New Member
    centerville, IA
    Wait what the @#$% is this?! There is meant to be brackets that hold the lowers together? Lol mine is just bolted together............. I don't see any place that looks like it had brackets in the past
  8. artee
    artee New Member
    Rochdale,
    Thanks for the replies.
    Looks like I am going to have to make some.
    Roger
  9. artee
    artee New Member
    Rochdale,
    Its the riveted plates that are missing.
