86 vf 500 Oily Front Rotor?
Discussion in 'Mechanics Garage' started by Bordecai, May 11, 2012.
  1. Bordecai
    Bordecai New Member
    St. Louis, MO
    I am new to street bikes, but I'm pretty sure my front rotor should not feel oily to the touch. It seems to stop fine, any ideas where it's coming from?
    Could the fork oil find it's way to the rotor?
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    Yep. Most likely fork oil.
    Replace both fork seals, AND your brake pads.
  3. DaHose
    DaHose New Member
    Napa, CA.
    Check at the stanchion wipers/seals. If the oil trail works its way down the bottom of the fork leg, then I agree it's likely oil.
    If it is clean up there, then check for leaking brake fluid.
    I second replacing the brake pads regardless of what is on there.
    Jose
  4. pjvtec
    pjvtec New Member
    West Allis, WI
    Any Anti-dive components? You would totally see fork oil running down the outer tube.
  5. Bordecai
    Bordecai New Member
    St. Louis, MO
    Where's the best place to buy new pads and seals?
  6. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    From your Honda dealer or Honda on the intarwebs. Aftermarket yields no gains here.
    Be sure to change the copper crush washers on the drain bolts and the allen bolt on the bottom.
  7. Bordecai
    Bordecai New Member
    St. Louis, MO
    is it worth putting performance rotors on at this point?
    If your rotors aren't grooved, warped, or less than the min. thickness, I would spend money elsewhere for now.
    Just be sure to clean them real good. SOS pad works great, be sure to THOROUGHLY rinse.
  9. Bordecai
    Bordecai New Member
    St. Louis, MO
    You're probably right, is the minimum thickness in my borrowed clymer's or do I need a factory manual?
    Pretty sure it's stamped in the rotor somewhere. Think it's 4.5 or 5 mm. Someone will chime in soon and verify.
  11. Bordecai
    Bordecai New Member
    St. Louis, MO
    Good call, it's stamped on the rotor, 4 mm on mine. Thanks again.
