'86 VF500 F ilde jet screw O rings and washers question
Discussion in 'Mechanics Garage' started by Dr. Jay, Mar 28, 2014.
  1. Dr. Jay
    Dr. Jay New Member
    Deland Florida
    Hi All,
    Thanks to all the help I've gotten from forum my VF500 F carbs are fully cleaned, reassembled and almost ready to put back on. I will bench test for leaks soon. However, I do see that while my idle enrichment screws are in very good shape, they are missing the washer and O ring near the tip shown in the FSM. The previous owner said it idled and ran fine, but I'm thinking they probably should be replaced.
    So, do I really need them for a rough and ready "get it on the road" project bike and if so where can I get them? Also if they are not readily available, can they be cobbled up with readily available O rings and washers as opposed to Honda parts?
    Thanks!
    Jay
  2. kennybobby
    kennybobby New Member
    Sometimes they get stuck down in the bottom of the hole and you have to fish them out with a bent wire hook--it can look empty if the washer is covering the oring. Probably won't run well without the orings.
    But i bought a big pack of 3 x 1mm Buna orings on ebay that seem to work fine, not sure what the actual OEM size is or if there exists for example a 2.95 x 0.95 Send me your address and i can mail you a set. i don't think i have any of the 3 x1 washers, but they should be readily available at any RC/hobby or hardware/fastener store.
  3. Dr. Jay
    Dr. Jay New Member
    Deland Florida
    Thanks! e mail sent.
  4. squirrelman
    Going far out on a limb like a squirrel............i think bike will idle fine without O-ring and washer :eek:, but both are needed to help compress screw spring or it can vibrate loose. :topsy_turvy::redface: Try a big gob of silicone seal over the idle screw holes to stop any possible air leaks the O-ring might prevent.
    I'm going to run this experiment sometime this summer.
