86 vf500f Carb question
Discussion in 'Mechanics Garage' started by fitfour, Nov 16, 2016.
  1. fitfour
    fitfour New Member
    Anyone know where this vacuum tube is supposed to attach to?
  2. kennybobby
    kennybobby New Member
    Did you actually measure vacuum on that line, or could it be a breather vent line?
    i wouldn't be using clear PVC plastic tubing for fuel lines unless you want to catch your bike on fire and burn it up--get fuel-rated rubber tubing from any auto parts store.
  3. fitfour
    fitfour New Member
    The fuel lines are metal tubes between the carbs. That should be a vacuum tube to the diaphragm chambers shouldn't it? It didn't even have a hose on that pipe when I bought it
  4. fitfour
    fitfour New Member
    Sorry was super tired when first reading your reply. I will get right on that thank you.
  5. squirrelman
    IF you found the time to read the service manual section on carbs you might have figured out that the unplugged hose was a vent line that must be open to atmospheric air. :eagerness:
  6. Boesjhoar
    Boesjhoar New Member
    Netherlands
    Doesn't it need to be attached to the aluminum air filter mount above? In the '84 carb it should be
    Verzonden vanaf mijn iPhone met Tapatalk
  7. squirrelman
