'86 VF500F - Electrical diagnosing help needed
Discussion in '1st & 2nd Generation 1983-1989' started by Mushosho, Apr 22, 2015.
  1. Mushosho
    Mushosho New Member
    After a long winter I was hoping to take the '86 VF500F out of the basement.
    Work done whilst waiting for snow to melt:
    Replace burnt out dashlights (thought this was causing a 10amp to pop - not the case)
    Disconnect and remove blinkers (this now allowed dash lights and running tail light to work, which prior were not)
    Problems created:
    Neutral indicator no longer functions (not burnt out)
    Idle at neutral = purrfect
    1st or 2nd (with clutch engaged = misfiring / lagging of engine, pulsing of headlight and dashlights in time with the lag/misfire) - I hope to post video/sound evidence of this soon.
    However - when we are in 1st or 2nd AND the brake is engaged enough to turn on the brake light -- normal idle again.
    Cheers,
    K
