86 vf500f high idle
Discussion in '1st & 2nd Generation 1983-1989' started by Jakeostler, Apr 6, 2015.
  1. Jakeostler
    Jakeostler New Member
    I just got this bike a couple weeks ago and i cleaned the carbs and put a new battery in it and it started right up but it idles really high. on the tach it ranges from about 3-5k rpms. Any suggestions?
  2. MB_ED
    MB_ED New Member
    Bethesda MD
    Possible vacuum leak? Is the carb rack seated all the way into the boots and are the clamps tight? If you turn the handlebars does the idle go down? (possible cable routing)
    Just a couple of thoughts
  3. Jakeostler
    I think the carb rack is seated all the way. I got them in as far as possible. I do know the clamps are tight. And no the idle doesnt change when I turn the handle bars. i did spray some starter fluid on the boots while it was running and it jumped up around 7k. So I think I might just have hard boots that are not sealing properly. Is there another way of testing if they are bad? Will boots from a 84/85 vf500f fit my 86?
  4. NormK
    NormK New Member
    You answered your question, the fact the revs jump up means the boots are leaking
  5. Jakeostler
    Do you know if the boots off a 84/85 will fit the 86 interceptor?
  6. desktopdave
    desktopdave New Member
    Pittsburgh, PA
    According to Partzilla, those insulator boots (PN 16211-ML7-000) are only common with the '86-'87 VFR, not the 500 Interceptor or any other Honda. If they look similar in size I'd try it out anyway. The VF500F does use really small carbs, but they might be close enough to fit.
    The VFR uses insulators that are slightly different than the earlier types, with cut-outs for the carb and cylinder heads. They're directional too...even have 'carb' printed on the upstream side.
    http://www.partzilla.com/parts/detail/honda/HP-16211-ML7-000.html
    I've also been tempted to repair those boots temporarily with a smear of black RTV or shoe goo, although it'd be a bad day if that stuff somehow got sucked into the intake valves. RTV is pretty vulnerable to warm gasoline, especially if it's blended with alcohol.
  7. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    " Will boots from a 84/85 vf500f fit my 86? "
    Don't think so. Carbs are a different size. the 86 carbs are smaller than the 84/85.
