'86 VF500F main jets
Discussion in '1st & 2nd Generation 1983-1989' started by creaky, Aug 1, 2011.
  1. creaky
    creaky New Member
    Need help from the experts. I am in the process of cleaning up a set of '86 VF500F carbs, 49 state model. The manual states that the main jets should be # 90, all 4 carbs. The carbs for cylinders 1 & 3 are fitted with #92s, the carbs for cylinders 2 & 4 are fitted with # 95s. I need some clarification here. Are these jets fitted because they provide a performance improvement? Or, has someone screwed up and fitted the wrong jets?
  2. invisible cities
    invisible cities New Member
    new york
    Could be:
    Not sure why FP has the '86 setup this way but they do.
    For reference:
    VF500F Carburetor Specs
    '84
    Model No. VD56A - 32mm Throttle Bore, 6.2mm Float, 102F/105R Main
    '85
    Model No. VD56D - 32mm Throttle Bore, 6.2mm Float, 90F/90R Main
    '86
    Model No. VD31AB - 30mm Throttle Bore, 7.3mm Float, 90F/90R Main
  3. creaky
    creaky New Member
    Thanks for the info IC. I will assume that the jets will work OK and put them back in. BTW, the slow jets are the stock #35s. The carbs were pretty gummed, photo attached.
  4. invisible cities
    new york
    Yikes!
  5. tinkerinWstuff
    that doesn't look like gummed up, it looks like corrosion. something appears to have been run through the carbs, possibly for storage, that turned out to be a problem for the brass parts.
  6. creaky
    creaky New Member
    The stuff was kind of gooey, black with a little green mixed in, but cleaned up pretty well considering.....
