86 vf500f transmition or clutch squeal, why?
Discussion in '1st & 2nd Generation 1983-1989' started by timmyklus, Aug 1, 2014.
  1. timmyklus
    timmyklus New Member
    I just finishd rebuilding the rear head on my 86 vf500f and now that I have it back together the transmition or clutch is making a squeling sound. it seems to do it more after the bike warms up. it does it in neutral or any other gear (makes me think clutch issue) and it onbly happens when the clutch lever is out. if I pull the clutch in slightly it will go away. it sounds like a powersteering belt on a car. If I pull the clutch lever in even an 1/8 of an inch it goes away.
    Any ideas what would cause this. I have spent a fair amount of time searching the net with no luck
    It runs great now with the rebuilt head though...
    Thanks for the help,
    Tim
    I am running castrol ATV oil, 10-40 weight
  2. timmyklus
    I think it might be this guy but I need to tear it apart...
  3. TOE CUTTER
    That would be my first guess as well.
    That bearing is bathed in oil and I've never seen one fail. My 86 had the same sound and I finally tracked it to the end of the clutch rod on the slave cylinder end. The rod will spin in some cases and squeals in the slave cyl. That's why it goes away when you put the slightest pull on the clutch lever and engage the bearing. Every now and then I need to apply some grease or moly paste. It started after I put in my Barnett clutch.
  5. timmyklus
    that sounds like the issue, I will tear the slave cylinder off and put a bit of grease on the end and see if it goes away. that sure would be nice :)
    Thanks for the great idea.
  6. MB85VF
    MB85VF New Member
    Trying to figure out what you mean by clutch rod on slave cylinder head. Where is it on the diagram?
    The slave cyl mounted on the left sprocket cover that says, "hydraulic clutch". Take that off (3 bolts), there will be the end of the clutch push rod that gets pushed by the cyl. That's the spot.
  8. timmyklus
    Grease location
    Here is where you put the grease. I just put a little dab on the end of the shaft and reinstalled the slave cylinder.
  9. Lobotomy
    Lobotomy New Member
    Toronto Ontario
    Be very care full when retightening the three bolts on the slave
    cylinder they can strip very easily.
