86 vfr 2nd gear jamming / grinding - overhaul tips?
Discussion in 'Mechanics Garage' started by FstaRocka, May 7, 2013.
  1. FstaRocka
    FstaRocka New Member
    Cape town, Seattle
    hi chaps. gonna be back at my 86 750 viffer soon (God willing), and its time i pulled the motor. luckily i have a spare. Ive taken a 77 cb750 apart before, lthought gears were good. anyone here pulled the trans out? my 2nd is un usable - prob from the prev owner crashing it or something, i paid so little - thought id ask for any q's - if my donor is fine, i could just inspect and swap out the whole unit, or should/could i just replace 2nd?
    iirc another gear also shows similar signs of slipping.. 4th or 5th.. ive been shifting 1-3rd since i put the thing together - otherwise runs like a champ. front brake lever is stiff compared to prev 84 750 vf - is this a cylinder hone/seal replacement?
    tx
  2. TOE CUTTER
    You should replace the shafts and gears as a complete set, it is always a concern when doing transmission repairs where only the damaged gears are replaced that the new gears will cause excessive whine as the are worn differently.
  3. FstaRocka
    Cape town, Seattle
    ... and wear down faster i take it. iirc the cb750 i did had the gears sitting on shafts and engaging onto the 2ndary shaft of gears. are the gear sprockets matched or do they swap around? ie could I swap the 2nd partner gears as a work around or will that not work?
    either way itll be easier to toss in the whole donor gear set as a unit though.
    the donor is the same motor, possibly a 700, did they have the same gear ratios? Anyone with some pics of the gears / disssembley?
    I bought a workshop manual but heaven knows where its laying around!
