86 vfr 700 750 engine cases
Discussion in '1st & 2nd Generation 1983-1989' started by rcfoggy, Jul 17, 2012.
  1. rcfoggy
    rcfoggy New Member
    Fairfield Ohio
    Are 86 vfr 750 cases interchangeable with 86 87 700 engine cases.bought a 86 vfr 750 but it has cylinder damage in one cylinder.
    Thanks,
    Gary
  2. TOE CUTTER
    They are the same but would sleeve the bad hole and avoid the bearing issues you are gonna have with a case swap.My two pennies after searching for bearings.
