86 vfr 750 f can't get it to run ......HELP
Discussion in 'Mechanics Garage' started by oktorock, Jul 24, 2015.
  1. oktorock
    oktorock New Member
    I had to replace the carb set, the bike hasn't ran sense,the carb were clean,valve were ajusted
    tryed to sync carb but was unable to,i'll take it around the block , at first it runs good but haft way around the block it will fall on it face,when i try to shif into sec gear and give it some gas it fall on it face, but when i let off the gas it take of sec it will start to take off again,don't know if this is a flot or jets issus or vac or fuel dleaver issus if anyone has any ided what i can do please help thanks
  2. NormK
    NormK New Member
    Looks like SOW got a new name
  3. Allyance
    Allyance Member
    East Bay, California
    Sounds like fuel starvation, check your fuel filter, check fuel pump and lines.
  4. squirrelman
    Quite possibly the slide diaphrams are not seated properly in their grooves.
    In any case you had best let a very experienced carb fixer (like me !) go through and inspect, clean, assemble, and precisely adjust the carbs so you know they're done correctly. Step one in getting your bike to run right !
    PM me if you're interested in my professional carb rebuild services. :courage:
  5. Allyance
    Allyance Member
    Squirelman, tried to send you PM,but your Inbox is full!:confusion:
  6. squirrelman
    All OK now. :cool: Thanks for letting me know.
