86 VFR 750 Rear wheel collars
Discussion in '1st & 2nd Generation 1983-1989' started by WayneC, Aug 7, 2013.
  1. WayneC
    WayneC New Member
    Cape Town, South Africa
    Hi
    Could someone please give me the diamentions of the collers that fit into the oil seals on a VFR 750 FG. Mine were swopped out by
    someone who also stole the rubbers from my cush drive. It a long long story.
    Here is a photo of the one I have which are the wrong size. DSCF1828.jpg Photo by waynec2 | Photobucket
    A friend of mine has a lathe and will make up the correct spacers if I can get him the correct diamentions. The collers I have are too narrow
    and dont even fit into the oil seals! The wheel also stiffens up when the axel nut is tightened.
    Thanks,
    Wayne
    Just order them from a European dealer or breakers yard. The 2 outer spacers wouldn't be too hard to fab, but the special spacer between the drive hub and left side wheel bearing is too complex for home brewers, and missing that is what causes your wheel to bind and can ruin the rear wheel bearings if the axle is tightened without it !!!!
  3. WayneC
    WayneC New Member
    Hi Squirrelman
    The 86 VFR was never released here in South Africa which makes it a rare beast. Honda Cape Town refuse to help me due to this. They say my bike
    a grey import and its my problem. The complex spacer is there and looks like the real thing. The collars are simple if they were the right size. They do not even fit into the oil seals and I think they too narrow as well.
    Thanks,
    Wayne
  4. squirrelman
    OK, you need dimensions from someone who has access to those spacers off a bike for measurements, and i no can do. Order them from David Silver Spares in jolly old.
  5. artee
    artee New Member
    Rochdale,
    I may have a set.
    Let me have a look. They are the same as the 87/fh, was that model availabe in SA?
    You can have them for postage from UK if you want ( if I can find them )
    Oh re above reply... David Silver is in the UK
    Roger
  6. WayneC
    WayneC New Member
    Hi Roger
    Thanks soooo much if you can locate them that would be great :) I'll try getting my paws on some pounds in the meantime.
    Thanks,
    Wayne
  7. artee
    artee New Member
    Rochdale,
    Hi
    I can send you the sizes of them, then you can have some made.
    It may be cheaper this way.
    This is all subject to me finding them.
    Because of the time taken to respond to my reply I didnt look for them straight away.
    I will look through my pile of bits and get a price for postage.
    Roger
  8. WayneC
    WayneC New Member
    Rear wheel spacers
    Hi
    How the hunt comming along? I just need the measurements.
    Cheers mate,
    Wayne
  9. artee
    artee New Member
    Rochdale,
    Sorry cant find them.
    Got a friend who is doing the cbr600 wheel conversion, so I have asked him for the sizes of the original spacers.
    When he gets back to me I will email you them.
    Roger
  10. WayneC
    WayneC New Member
    Thanks mate. You a star! :)
    Cheers,
    Wayne
