86 VFR removal RH timing cover
Discussion in '1st & 2nd Generation 1983-1989' started by chuntera, Oct 16, 2019.
  1. chuntera
    chuntera New Member
    Connecticut, USA
    Right side engine on 86 & 87 vfr700 has a small round aluminum cover that can be unscrewed. This cover is removed to manually rotate engine when setting valve clearances. My experience the cover is often over-tightened and can't be removed without damage.
    Anybody have any tips for damage-free way to remove cover ?
    place a wood block against the cover and rap with a hammer. put a socket on nut and coordinate a hammer blow with turning. try some heat.
    setting valves it's easy to bump crank around with starter or in gear using rear wheel.
  3. RS125
    Could always use a dead blow hammer. Good tool to have. Most places carry them... That's one from Advance Auto parts
  4. chuntera
    chuntera New Member
    Connecticut, USA
    I used a plastic chisel/scrapper tool which still left a mark.
    I'm missing a third hand to try this out :p
  5. squirrelman
    takes coordination and exact timing
  6. Diving Pete
    Don't worry about taking off the small round cover - take the whole side cover off - just get a gasket this will help you then remove the round cover easier.
