Wanted 86 VFR Shock Linkage - Found
Discussion in 'Classifieds' started by jkboyd, Nov 18, 2025.
  1. jkboyd
    jkboyd Insider
    Havre de Grace, MD
    I'm looking for the shock linkage for an 86 VFR. I'm doing the F2 wheel conversion on an 87 and need the 86 linkage to raise the rear ride height. Thanks
    I went to the stash. I had one of each, 86 & 87. If I had two 86 you would have one. Sorry.
    I donated one to a buddy for the same reason, but I thought I had an extra extra. If I come across it I will let you know.
    I don't know how there's not like 12 of them on eBay right now for $25-30. You probably discovered the same thing.
    Good luck.
    rc24dk likes this.
  3. jkboyd
    jkboyd Insider
    Havre de Grace, MD
    Thanks I appreciate you looking. Yeah, I thought the same thing that there'd be several on ebay. But I figured if there was it would be hit or miss whether it was an 86 linkage, I'm sure that some folks think the 86 and 87 linkages are the same. Joe Nelson said he thinks he has one and is going to check when he gets a chance.
    Thanks again, and I appreciate your posts, I've learned a lot. I'm looking through your 92 VFR750 rescue/refresh as we speak. Lol
    Captain 80s likes this.
    For future reference if needed, the 86 version has "ML7" cast in it, the 87 does not.
    And here is an example of an 87. "ML7" would be cast right around here (red area) on the 86 version.
    Another tell is if it comes with the "Connecting Rod", the 87 used a plate and tube type construction, not the cast piece on an 86. The two styles of the Connecting Rod are dimensionally identical and can be interchanged.
  6. jkboyd
    jkboyd Insider
    Havre de Grace, MD
    Thanks for the info., that's good to know. Were the fork internals the same between the two years? They look identical on the outside but I figure since Honda tweaked the rear suspension they probably tweaked the front too.
    The damper rod did change part numbers but I wouldn't attribute any real world difference. Stock 87 might be a touch more compliant. But still only as good as a damper rod fork can perform.
  8. jkboyd
    jkboyd Insider
    Havre de Grace, MD
    One things for sure, I wouldn't be able to tell the difference!
  9. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Found this on eBay- might work:
    86 HONDA VFR 700 F VF 750 F INTERCEPTOR ALUMINUM SWING ARM 52100-ML7 1986
    THIS IS A GOOD USED REAR WHEEL SWINGARM ASSEMBLY WITH SHOCK LINKAGE AND REAR BRAKE CALIPER STAY ARM FOR THE FOLLOWING HONDA MODELS LISTED BELOW. COMES COMPLETE AS PICTURED.
    Plug that in to this sellers store:
    Cycles Cars and Collectibles
  10. Bazza
    Bazza Member
    You could always ask them to remove and ship just what you want (the linkage) to reduce cost.
    Also, there's only 1 photo on the auction site, so do your due diligence as needed.
  11. jkboyd
    jkboyd Insider
    Havre de Grace, MD
    Thanks Bazza, I appreciate it. I did find the linkage, Joe Nelson had one. Thanks again!
    Bazza and Captain 80s like this.
  12. Bazza
    Bazza Member
    Fantastic! :)
    jkboyd likes this.
