86 VFR thermostat replacement
Discussion in '1st & 2nd Generation 1983-1989' started by midias, Aug 4, 2014.
  1. midias
    midias New Member
    Rochester NY
    Does anyone know if any automotive thermostats fit the 86 VFR?
    I know which ones fit my magna but was not sure if they are the same. I contacted the local honda dealers and none are in stock and was hoping to get it back together tonight.
  2. ThatVF500Guy
    ThatVF500Guy New Member
    Atlanta, GA
    Yeah. Do a search. I think I used one from a Geo Tracker.
  3. midias
    midias New Member
    Rochester NY
    Thanks I found a PN on here and crossed it to a duralast 15848 thermostat. I had to drill a 1/8" hole in it but I got it working. I also replaced the fuel filter with a FF3419DL which crosses to a WIX 33033 or fram G15
  4. ridervfr
    They want that hole facing the front of the housing on the t-stat housing, least they did on the gen 3 bikes.
  5. midias
    midias New Member
    Rochester NY
    Honestly I cannot remember where I drilled it but I know I put it in the same place as the factory one.
