86 VFR700 Chain and sprocket replacement
Discussion in 'Mechanics Garage' started by TLov07, Jun 13, 2011.
  1. TLov07
    TLov07 New Member
    Dayton, Ohio
    I searched around a bit and couldn't find much help. I was wondering where to purchase a quality chain and what is a good tooth adjustment either front back or both for more power. I plan on replacing the chain and both sprockets. Thanks in advance.
  2. fatso1277
    fatso1277 New Member
    South Suburb IL.
    JT SPROCKET from what i heard. i heard the 520 chain conversion works(u can search that hear)..mixed reviews on it though. 2 up in back and 1 down in front. or stock front and 2 up in back...i think over all the 2 up in rear offers more acceleration...i think i remember reading. but it will throw ure speedo off.
  3. TLov07
    TLov07 New Member
    Dayton, Ohio
    Thanks for the response. I think the speed reading for the 86 comes off of the front tires rotation so I wouldn't imagine it being affected by a sprocket change. Or would it?
    Can I get a chain from the dealer and then get aftermarket sprokets with the 2 more teeth in the rear or does it require a different chain setup all together?
    Any info is helpful. Thanks again.
  4. squirrelman
    No chain/sprocket setup will find you more power, but you can improve acceleration at the cost of increased engine wear and noise and worse fuel economy by changing sprockets.
    Stock Honda front sprocket is quieter than any aftermarket cuz of rubber dampers, and you should stick with a steel rear sprocket, cuz alloy will wear about 3X faster.
    You need to find a quality, name-brand O-ring chain online.
    Replacing components is not cheap, and for durable parts that last, you'll need to spend about $140-$180.
  5. camo
    camo New Member
    The Heartland
    I would stick to 530 and go with a less expensive O-Ring chain, they all wear out sooner or later. If you believe the manufacturers info, the 530s will have higher tensile strength for the money than a 520. Measure the chain under tension and change it when it wears (elongates) 3%, the starting value is 5/8" per link. My 86 came with 16/46 JT sprockets. I ride a lot of 2 lane roads and it works pretty well. I switched to a 750 engine and am getting 46 mpg.
  6. TLov07
    TLov07 New Member
    Dayton, Ohio
    Are 16/46 JT sprockets stock? How many links does your chain have?
  7. fatso1277
    South Suburb IL.
    16 / 46 is stock for 700. i think a 110 link o ring chain will work from my research.
  8. camo
    camo New Member
    The Heartland
    Thanks Fatso, I wondered whether my bike was stock.
  9. cjbiker72
    cjbiker72 New Member
    toledo, oh
    i did mine about a month ago. same bike, 86 vfr700. jt sprockets is what i got, 16/46 and a 530/110 DID chain. no problems at all.
  10. Rod Moran
    Rod Moran New Member
    Southwestern Ontario
    I'm looking for the torque spec. for the rear axle nut on a 1986 VFR750 if anyone has it,
    Thanks.
    Rod
  11. squirrelman
    why not get a manual ?? you need one.
    book says 65-77 ft-lbs.
  12. Rod Moran
    I know I need a manual. I've been spending on this thing as fast as possible since acquiring it recently. Chain and sprockets and brake pads and fork seals took precedent over a manual. Thanks for the info, I'll have to rely on VFRworld until I can fit the new book into the budget.
  13. squirrelman
    cancha download a manual online ?
    Rod Moran likes this.
  14. Rod Moran
    I'll do that as soon as I get 5 minutes to, I had one of these back in 1987 and have had the 2003 VTEC 800, VIFFERS RULE! I had the VF1000R, never should have sold that one.
