86 VFR700 High Idle after warm up
Discussion in 'Mechanics Garage' started by pasta_bob, Jul 29, 2017.
Tags:
  1. pasta_bob
    pasta_bob New Member
    I recently picked up an 86 VFR700. After the engine gets a chance to warm up the idle climbs way up to 4000(ish) rpm and never comes back down. The guy said he had recently replaced the carb O rings and had not had a chance to sync them since. Is this possible. I am currently whipping up a dyi vacuum meter to try and balance them. What other things might I want to inspect first before trying to sync the carbs?? Bit of a bike noob here but any help would be extremely appreciated.
    you already tried backing out the idle speed adjusting screw ?? does the bike idle OK before warming up ? check that the carbs, boots and cylinder intakes are fully seated. spray carb cleaner around the boots while running to check for air leaks. O-rings ?? which ones ?
  3. pasta_bob
    Have not been able to locate the idle adjust screw...when i plugged in my vacuum meter it said that the front right carb (#4?) is pulling the hardest by a substantial amount. I will check for leaks tomorrow. It seemed to idle somewhat smoothly when it was colder but at higher rpms seemed a bit rougher. as far as O rings I do not know I texted him so we will see what he says.
  4. pasta_bob
    Well i decided to say screw it and get to know the girl so I pulled the carb today and did a full clean and bench sync. One of the boots looks less than ideal so guess theres a chance it was leaking.
    With the carb off i noticed a bit of carbon build up on the plunger looking guys (valves?!?). Saw some videos of people on the internet pouring some cleaner in there. Is this advisable or might i do more harm than good? Thought it made since as i have the carbs off
  5. derstuka
    San Diego, CA
    Hello and welcome pasta bob! Throw up an intro thread when you have a chance
  6. squirrelman
    carbon there is normal, so don't do anything. carbs are fragile; don't drop them !
    remember, you can't be certain slow jets are fully clean and open until you can push a .010" wire through the jet.
