hello, I am trying to get this bike back on the road and its not going very well, it has been sitting for about 14 years in a nice dry garage, the problem is it has no spark at any plug, probably the reason it was parked, I have checked all the connections, which seem tight, I have noticed one thing odd about the kill switch, the starter turns the motor in the on and off positions, which I know is not right, just not sure what to do to find the cause. I am not very good at electronics so any help would be greatly appreciated. thanks
I would check your main fuses...the engine will turn over even if the kill switch is off.....it just won't let it ignite..... check your coil packs..make sure they are getting juice, then check the spark box thingy under the seat. make sure you have power to it...
a Honda service manual will answer your ques-ions and provide a plan for solving your problem........
