The rear brake master cylinder is leaking at the piston. Can the master cylinder be repaired or do I need a new unit? The bike is an 86 VFR750F. StanG
You should be able to order a master cylinder rebuilding kit (2 or 3 rubber parts--2 seals and a dustboot-- & a spring) from your Honda dealer, fairly cheap.
