'87 Rear Turn Signal Bracket
Discussion in '1st & 2nd Generation 1983-1989' started by Pie, Feb 3, 2015.
  1. Pie
    Pie New Member
    Good Day all,
    Wanted to get your opinion on a Turn Signal bracket issue I have.
    The rear signal sheared off on my Interceptor, and I've been looking around to figure out a solution to repair or replace the piece.
    The metal is so thin, it would be idiotic to JB Weld, so I wanted to see if anyone had any solutions for this particular part's replacement:
    The sheared area attaches to the frame, the portion where the screw is goes into the signal assembly itself and is attached through the bottom of the signal.
    Just buy a new cheap Chinese look-alike signal mounting stem online.
    OEM stalks come in 3 lengths: 47mm, 34mm, and 23mm.
