87 vfr700 headlamp bucket removal??
Discussion in '1st & 2nd Generation 1983-1989' started by Gregg in ohio, May 26, 2012.
  1. Gregg in ohio
    Gregg in ohio New Member
    kenton ohio
    removed my head lite and need to separate..the rear bucket from the lite ? how do i remove it thanks gregg in ohio
  2. Chris71Mach1
    Chris71Mach1 Member
    Grand Prairie, Texas, United States
    you dont. the headlight is an assembly. if the glass is cracked, you pretty much need a new headlight assy. sorry to be the bearer of bad news.
  3. orion3814
    orion3814 New Member
    fayetteville, ar
  4. JasonWW
    JasonWW New Member
    Hou. TX
    Try using a heatgun to soften the glue holding them together and then scrape the glue out and gently pry apart.
  5. squirrelman
    Why ??
    As stated by Chris, cracked glass means you need a replacement, not a repair.
  6. JasonWW
    JasonWW New Member
    Hou. TX
    OP might be installing projector headlight or cleaning reflector. He didn't say anything was cracked.
