92 VFR seeking Honda carb rebuild parts
Discussion in 'Mechanics Garage' started by thepathlesstaken, Nov 2, 2009.
  1. thepathlesstaken
    thepathlesstaken New Member
    San Diego
    Just wondering where I would go to find new float bowl gaskets and a full set Honda CV diaphragms for a 92' VFR?
    Did not find anything at K & L (bad search possibly) as far as an alternative to the $125.00 OEM per piece replacements that out there. The only float bowl gaskets I found were as a OEM Honda rebuild kit to the tune of $160.00 (for all four carbs).
    I might just buy a carb set off of ebay and be done with it, do I need to look for a 91-93 set with CA emissions since the VFR is a CA version?
    Thanks in advance!
    see if you can find the float bowl gaskets in a "Parts Unlimited" catalog at your local INDEPENDENT 'cycle shop.
