92 vfr - stiff steering
Discussion in '3rd & 4th Generation 1990-1997' started by manjirider, Aug 14, 2009.
  1. manjirider
    manjirider New Member
    hi guys,
    i recently bought a 92 vfr at auction that had been slid down the road on its left hand side. apart from fairing and indicator damage it looked pretty straight and only had 36000 kms. after sourcing the broken bits i got it licenced no problem and rode it home and everything was fine, except the steering. as an auctioned bike there was always the chance that the frame or forks would be bent but i don't think they are as it steers straight and everything lines up but it's really stiff to turn and has a very slight weave. could it just be head bearings or am i up for something more expensive? Any ideas or suggestions would be appreciated.
    cheers
    manjirider
    by the way, although it's showing an american flag next to my name, i'm an aussie from manjimup in western australia
  2. Jim Davis
    Jim Davis New Member
    Shizuoka, Japan
    When the steering bearings are a bit tight, a bike will weave. Since your bike went down, it's possible one of the steering bearings got nackered. I suggest you remove the front end and check, clean, replace, regrease, whatever you find you need to do. You can't ride it with stiff steering.
  3. squirrelman
    Most common cause of heavy steering is low tyre pressure, but you already checked that........?
  4. deepdish
    deepdish Banned
    I don't like steering when stiff either..........
  5. deepdish
    deepdish Banned
    tyre.............................:rolleyes:
  6. manjirider
    thanks guys, the steering head bearings sound like the first thing to check
  7. betarace
    betarace New Member
    Middleburg, VA
    more than likely overtightened, if so, more than likely flat spots on the bearings.
