93 vfr headlights randomly not working
Discussion in 'Mechanics Garage' started by jimmy.miller.969952, Feb 5, 2015.
  1. jimmy.miller.969952
    jimmy.miller.969952 New Member
    Arnold, California, United States
    Twice now, I've had my headlights randomly turn off on my bike. Just recently, I noticed that if I push the start button in halfway, it triggers the lights to come on, and if I monkey with it they will eventually stay on... Has anybody ever heard of this before? Where would I start to look?
  2. NormK
    NormK New Member
    Have a look under "intermittent headlight" in the mechanics garage, it was being discussed a couple of days ago
  3. rjgti
    rjgti New Member
    regina sk
    your start button would be my first spot to check
  4. ridervfr
    Check fuse block, you know where it is right? Front right cowl, check that fuse for the headlights, could be loose. Mine heated up over the years and would not stay tight, the new wiring harness I installed made the bike like new, everything is brighter and cured it. I tried headlight relays but that was not the ticket. Keep us posted
  5. tinkerinWstuff
    The starter button cuts out the headlights so you have full cranking amps to the starter.
    It's a common failure point. I used to be in the habit of giving mine a flick after cranking to make sure it was fully retracted.
  6. NormK
    NormK New Member
    Tinks, does the switch carry full power in the circuit or does it just switch a headlight relay, can it be bypassed
  7. tinkerinWstuff
    I do not remember for sure, sorry.
  8. rjgti
    rjgti New Member
    regina sk
    it can be bypassed
