94...Slightly lean surge under 4000
Discussion in '3rd & 4th Generation 1990-1997' started by manybrews, May 18, 2009.
  1. manybrews
    manybrews New Member
    Alright, as Im new to VFRs (but not cycles), ive discovered on mine that it seems to have a lean surge under 4000 RPMs. Noticable when Im stuck in slow traffic (35 mph, +-).
    Its annoying. I expect thats it also pretty typical, as its been my experience with everything honda that they like it lean and green.
    Doing a bit of searching seems to support that theory. So, my question is, how many of you do actually experience this, and whos rejetted to compensate? Im not a huge fan of dynojet kits, but they probably allow for more adjustment than the factory stuff.
    any advice? I can "drive through it", but its annoying nonetheless.
    I imagine if the factory needles allow for it, I could merely raise them a click or two.. But I dont know if they do.
  2. DGW
    DGW New Member
    Camarillo, Ca.
    I would suggest balancing your carbs if they haven't been done in a while.
  3. squirrelman
    MY '97 did the same thing.......until i installed a Dynojet kit, which cured all ills !!
    You could try shimming up stock needles (no notches) and opening up the mixture screws (if you have the proper tool and very small hands) but the best results are with Factory Pro or Dynojet. How many times do you want to wrestle with getting the carbs off and on??
    Do it once and do it right.
  4. dale-j
    dale-j New Member
    British Columbia, Canada
    My Dynojet kit (on a 93) didn't help much. Pretty disappointing after the expense of getting the kit and having it installed and tuned at a shop. A friend with a 95 used the Factory Pro kit and it was worlds better. It costs more than the Dynojet but as they say you get what you pay for... and the install costs the same (or takes the same amount of your time) and is a bigger part of the expense in any event.
  5. manybrews
    Thanks for the replies.
    I figured I was gonna hafta rejet... I just wanted to know whos had luck with which kits!
