'94 valve clearance: Which timing mark do I use?
Discussion in 'Mechanics Garage' started by Vifferaver, Jan 17, 2009.
  1. Vifferaver
    Vifferaver New Member
    I'm checking valve clearances on my '94 750F. The Honda manual refers to a timing "mark" but each 'T' mark has two scribe lines, one of which is longer for the #1 'T' mark. With this longer mark aligned with the index notch, the cam wheel marks correctly align with the cylinder head so it seems intuitive that the similarly-positioned 'T' mark for #2, #3 and #4 are the correct timing marks to refer to.
    The cam position difference seems insignificant at any point between the two 'T' marks so my question is, are these parameters within which the clearance may be checked or is one of the marks there for another purpose - (i.e., to confuse people), or maybe for race tuning? It's probably not important but out of curiosity, what is the purpose of the other two marks between the 'T' marks?
    Thanks in advance.
      File size:
      45.7 KB
      21
      File size:
      43 KB
      22
  2. dizzy
    dizzy New Member
    MN
    You would use the scribed T mark...the scribed line marked F is the ignition timing mark...and the two scribed lines that aren't marked are ignition timing full advance.
  3. Vifferaver
    Thanks for clarifying that. I see it now under 'Ignition Timing' in the book.:wink:
  4. squirrelman
    marks are not very important for checking valves as long as the cam lobe is generally pointing away from the bucket.....
