95 Pilot jet tool. WTB
Discussion in 'General VFR Discussions' started by Gatekeeper, Jan 20, 2007.
  1. Gatekeeper
    Gatekeeper New Member
    Does anyone one know where to obtain the goofy tool to adjust the pilot jet?
    If I could get them out while the carbs are on the bike, I'd just file a slot in 'em for a screwdriver.
    Just picked up a VFR from a guy from about 6000' altitude differance and need to adjust the carbs. (It acts like one carb has had the screw back way out.)
    Beige smoke at idle that clears off idle and the pipe tips very sooty. Plugs dry and black except cylinder #2, which is somewhat wet and black around the electrode.
    TIA.
  2. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
  3. RVFR
    That's sweet, way better looking than the one Honda uses, Hmm $90 thou I've been thinking about doing mine, thing is for the set up you also need a tach that's able to detect a 50 rpm change after you have the initial settings in place. cool to know though, thanks
  4. Ferris
    Ferris New Member
    Nashville, Tennessee
    Second that on the Motion Pro tool. They make good stuff.
    You already have the 50 RPM change detection tools, RV - they are attached to the sides of your head!
  5. Rev
    Rev New Member
    Olympia,WA
    We could all pitch in and buy one, then when one of us is done with it, send it to another part of the country, making sure we all sign it before it goes and...
  6. Gatekeeper
    Thanks for the MP tool link. I didn't see it when I went through the catalog!
    I found the Honda tool number and it is the same price. Think I'll get the MP as it has more adapters. (Already had the flat screwdriver one from doing most any other bike I've ever worked on!)
