Are the carb needles on a 1995 different sizes for the front vs rear carb bodies? The part numbers are different on the parts fiche. I could be wrong but if they are different, is there a way to tell the difference.
Borg..don’t know where your info is from, parts list I’ve found(mrcycle) shows needles as same #’s, also no longer available. If you have parts in the carbs that look different they could be something from aftermarket supplier(s)
