I was wondering if anyone could help me out here. I need to replace both headlight bulbs on my 95 VFR seeing as the high beams have burned out on both. Can anyone please give me a detailed list on how to remove and replace the bulbs. Thanks for all the help in advance. edit: After talking to the dealer I was told it is a pretty easy job to do by myself. THe only thing I can not figure out is how to actualy remove the plastic seal and bulb from the light fixture itself. Seeing as I do not want to ruin anything, some ideas on how to do this would be apreciated.
From memory....... pull the rubber seal away from the back of the headlight assy. Squeeze the wire retaining clip together and swing it away from bulb. Replace bulb, reinstall wire retaining clip and rubber seal. Id be weary of the fact that both bulbs are out at the same time though. Not common.
Thanks for the help. And the only reason both high beams are out is because I waited to replace the first one that burnt out about 2 weeks ago, then the other one went out on Friday night.
