96 vfr 750 question
Discussion in 'Introductions' started by vfrpeeps96, Jul 26, 2009.
  1. vfrpeeps96
    vfrpeeps96 New Member
    Fallston, MD
    i was hoping to see if someone could help me. i need the tail piece that holds the rear tail light up next to the blinkers, my bolt is missing and it seems like it cracked off so i need a whole new piece
  2. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    The lower piece with the reflector on it or the top half moon piece?
  3. RVFR
    same ???? that or Service Honda could be your new best friend..
    1-800-828-5498
  4. vfrpeeps96
    Fallston, MD
    [​IMG]its actually the piece where the bolt holds the reflector portion to the rear side fairing. they are both broken so i guess i have to replace both?
  5. vfrpeeps96
    Fallston, MD
    i was also wondering if i could get a tail in one piece??? can tails be interchanged without much modification? sorry about all the questions i'm new
  6. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Thurn Motorsports makes onepiece tails for $$$. you might try to use some plastic weld on the tabs and cracks. Its worked for me in the past to glue stuff back together. Its a 2 part epoxy.
  7. vfrpeeps96
    Fallston, MD
    since the piece i will be wielding is connecting two fairingsis there a certain patch i should use and i need a fix that will pass inspection
  8. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Inspection? I would try to repair separately if possible. Can you take a good picture of what you are up against and we will have a better time trying to help. Brian
  9. vfrpeeps96
    Fallston, MD
    yea i have temp tags on it and it won't pass inspection without the back being fixed. i think i have a plan and i'm going to document it as best i can so if someone else has this issue i can help. thanks for the suggestions.:thumbsup:
