96 VFR750F won't crank
Discussion in 'Mechanics Garage' started by mattiep321, Aug 9, 2020.
  1. mattiep321
    mattiep321 New Member
    Pulled bike out of storage after two years and put in a new battery and got her running today. Ran like garbage so I drained gas and bowls, put in fresh gas and now it won't turn over. It's almost like the starter winds up a little bit but the engine never turns over now. I put it in first gear on the center stand and can't get the tire to rotate either. I can't believe its sized up, what could it possibly be?
    Sent from my SM-G970U using Tapatalk
  2. Terry Smith
    Maybe you have filled a cylinder with over flowing fuel from a blocked float needle valve in the carb? Maybe pull the plugs out and see if the engine turns over/coughs out a cylinder full of fuel. Also check the oil level, fuel can run past the rings into the sump.
  3. mattiep321
    Okay, ill try both, thanks!
  4. squirrelman
    next time drain float bowls b4 storage.
  5. squirrelman
    RESULTS ?
