97 VFR fork tube diameter?
Discussion in 'Mechanics Garage' started by littleboy, Apr 21, 2012.
  1. littleboy
    littleboy New Member
    Thanks I found the dimension
    Standard nominal diameter is 41mm plus or minus whatever the factory allows within tolerance specs.
  3. littleboy
    THANK YOU for the dimension.
  4. littleboy
    Thank you for the dimension.
  5. squirrelman
    No, Sir ....if you or your son could drive a carabo or waterbuffalo through a field or rice paddy, you could manage a VFR also.
