98 vfr 800..rectifier issues
Discussion in '5th Generation 1998-2001' started by autopro6969, Jun 30, 2011.
  1. autopro6969
    autopro6969 New Member
    Hueytown, Alabama, United States
    I have an r 1 rectifier for my 98 vfr 800.I found out how to wire it...but , i saw a thread where someone tapped into the earth wire and live wire and run strait to the battery with a fuse in between to stabilize charging.Is this possible? if so,do i need to beef up the wires to the stator as well? ... is earth wire ground and live wire hot?:vtr2:
  2. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Save yourself the hassle and potential of frying something, go to wiremybike.com and get the VFRness. I have one on my 99 coupled with the ricks motorsport rectifier and it is perfect.
  3. ignoreance
    ignoreance New Member
    Santa Clarita
    A fuse would not stabilize charging your battery. If the fuse burns out it would actual stop charging the bike just guessing by the way you wrote it. Pictures would speak a 1000 words.
  4. camo
    camo New Member
    The Heartland
    Hi that is exactly how I wired my new R/R in. There is 10 gauge wire from my RR to the battery on both sides. The Plus side has a maxi fuse, Maxi Fuses. I used a Shindengen FH012 R/R.
    I had to be a bit creative on mounting. I moved it from under the seat to under the left side panel. I welded on two tabs onto the sub frame. I had to move the fuel pump to an under the seat location. I think the space was for a tool pouch.
    I read that my 86 vfr750 has a 30 amp alternator and the FH012 is a 50 amp unit. So far it only gets warm to the touch.
  5. fastrax203
    fastrax203 New Member
    Chesapeake, VA
    Is this stock??
  6. fastrax203
    Chesapeake, VA
    Oh, my bike's a '98. I think PO replaced the R/R with an OE one.
  7. ignoreance
    Santa Clarita
    If you didn't know this was out there here a link to the factory service manual in PDF form.
    Owners Manuals and other - VFR Discussion
    You have to be a member to download it but it will be pretty handy. I'm not sure why this board doesn't have the manuals if we do it is not an easy find like it was over there.
  8. michaelt863
    michaelt863 New Member
    For OUR generation VFR's, I Always keep a spare rectifier in parts bin(shop for best price OEM/Google) and chek that harness@ plug-in junction! Enjoy!
  9. autopro6969
    replaced oe rectifier with r1 rectifier. replaced all wiring to main harness,old wires were fried.now it holds a better charge on battery (starter turns over faster),and so for i havent had to buy any headlight bulbs!....total cost around $85.00.:bootyshake2:
