abs light
Discussion in '6th Generation 2002-2013' started by skechy, Jul 6, 2008.
  1. skechy
    skechy New Member
    Cambridge, Ontario
    hey there, i've been noticing my ABS light come on the past few nights only after having turned on my highbeams. it resets after i turn of the ignition, and hasnt come without the highbeams turned on. anyone else experience this problem? am i right to think ive got a short somewhere? thanks for any help.
  2. jasonsmith
    jasonsmith Member
    Vancouver, BC
    Have you done your electrical recalls yet? Sounds kinds fishy, which usually means the gremlins are a comin.
  3. 34468 Randy
    Check your owner's manual. It does say something in there about the ABS light. Mine comes of for a several seconds on start up but goes out. The manual on the 06 says it is supposed to do this. Haven't notices anything about the high beams though
  4. jasonsmith
    jasonsmith Member
    Vancouver, BC
    Yep, the ABS light should stay on when the ignition is powered on until 10kmh or 6mph is reached.
    Skechy, you can also attempt to "retrieve" a trouble code from your ABS unit when ya have the light fault. The procedure is in the service manual that you may have or that can be downloaded. My guess is that your high beams are taking a toll on your electrical system and the ABS is sensing the low voltage.
    Maybe throw a voltmeter on your battery when you get the ABS light and see what your voltage is at...
  5. 2007 VFR800AT Fan
    2007 VFR800AT Fan New Member
    Kitchener, ON, Canada
    Skechy, what did you figure it out to be? Recall for electrical not done, low voltage, or going out naturally after 10 kph?
    My wife just purchased a one year old VFR800AT and we noticed the ABS light on when she started the bike to go to work. (NOTE: I just called her as she would have arrived at work and the light went out pretty much right away when she drove down the road. I'm thinking the advice about 10 kmh seems accurate for our situation).
