adj carburatore pilots
Discussion in '1st & 2nd Generation 1983-1989' started by jafo, Apr 18, 2012.
  1. jafo
    jafo New Member
    Ithaca NY
    OK is there a site I can check on adjusting the Idle jets on
    the 700 seems that the Clymer I have runs me in circles.
    The bike runs like a raped ape but the Idle is still screwy.
    Also it is A little harder to start after warmed up.
  2. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
  3. squirrelman
    Runs worse when hot usually=running too rich. Inspect your sparkplugs for clues.
    Idle mixture screws can be adjusted, but idle jets cannot unless you use a drill.
    Bad synch usually causes rough idle, but you could experiment by playing with the mixture screws in or out to see if that helps.
