Adjustable levers only start in neutral
Discussion in 'Mechanics Garage' started by BDR1783, Aug 12, 2015.
  1. BDR1783
    BDR1783 New Member
    Virginia
    I just installed a set of eBay adjustable levers. They seem great but it will only start in neutral or if I back the adjuster to almost factory position. I like adjusted all the way in so only a few inches of travel. Just wondering if there is any way to correct this thanks.
  2. Terry Smith
    Sounds like the clutch switch is not quite engaging. I don't think this could be easily moved, so perhaps you could make the inside of the lever stick out a little more, e.g. by drilling and screwing in a small screw so the head engages with the tip of the microswitch? Or maybe a blob of solder in the right spot?
  3. SCguy
    SCguy New Member
    On my set, the first position that it will engage the clutch switch is 3.
  4. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Yeah, mine's the same way. You could build up the switch area with something if you want it to work, like Cadbury suggested.
