Adjusting the Idle Speed on a 8th Generation?
Discussion in '8th Generation 2014-Present' started by Allyance, Jan 10, 2015.
  1. Allyance
    Allyance Insider
    East Bay, California
    Haven't got my service manual yet, trying to figure how adjust the Idle. I know it has cables down to left side of the throttle body, where it converts to drive by wire. It was late, so I didn't want to start taking off left side cowls, so has any one done this yet? (lifted the tank, but not accessible).
    BTW, has any noticed that idle increases 200 rpm as you pull the clutch in?
  2. DriverDave
    DriverDave New Member
    Denver, CO
    First off, no need to remove anything to get to it. It's a black knob on the left side, up and to the left of the clutch slave cylinder (proper setting is 1200 +/-100 rpm) . Second, it is not ride by wire...standard twin cable from the throttle to the throttle body. Lastly, the idle increases as you let the clutch out. It's meant to help you take off without stalling it. You can check it the next time you're stopped at a light...just let clutch out a little and pull it back in.
    Hasan Burgaz and Coyote Chris like this.
  3. Allyance
    Allyance Insider
    Thanks, idling about 1800 then increase to 2000 rpm when I let clutch out. Will adjust tomorrow. Don't know where I got the idea about the ride by wire, in some bogus article.
  4. Allyance
    Allyance Insider
    I was thinking of the VFR1200, which does have drive by wire, and uses traditional cables to a transition unit.
  5. DriverDave
    Denver, CO
    You are correct, sir.
  6. Allyance
    Allyance Insider
    Thanks again, found the knob and adjusted idle. It was getting hot at long lights out here in CA. On my 03, it was on the right side.
    PS: Went for a ride, much better, ran a lot cooler in traffic.
  7. Hasan Burgaz
    Hasan Burgaz New Member
    Turkey
    It also worked for my 2015 Crossrunner. Thanks a lot!
