Advise / starter relay
Discussion in 'Mechanics Garage' started by dcompson, Nov 29, 2009.
  1. dcompson
    dcompson New Member
    Ok, ill try to make this short, then ill post pics to explain. A couple of months ago (i dont ride often) my 93 vfr started having electrical issues. Sometimes when i would turn the ign switch on, the bike would completely die. Then it would just come right back on and start just fine. When i say 'die' i mean all electrical would go out. I thought it was the battery, so i started poking around for loose connections. Look what i found.
    This is the plug that connects to the starter relay, see below.
    Should i....
    A Clean and re-use said plug?
    B Search for a new plug?
    C Search for a new wiring harness?
    Help?....
  2. steven113
    steven113 New Member
    Pensacola FL
    I would search for a new plug and relay. replacing the harness might be overkill. check with Wire My Bike for the connecter
  3. dcompson
    dcompson New Member
    Well, after some checking on wiremybike.com, it appears i need the vfrness kit. So, i just ordered it. It consists of a new plug and upgraded wiring to fix the underlying issue. Thanks again
    Dave
  4. squirrelman
    IT'S really a very common problem on ALL years VFs/VFRs
  5. TOE CUTTER
    +1 on that. The one I put together for Fredsncoma did not have the problem , had I not seen it for myself I would not have believed it.:eek:
