Air box
Discussion in 'General VFR Discussions' started by toadsear, Mar 3, 2016.
  1. toadsear
    toadsear New Member
    New here, 01 vfr, any thoughts about markings on air horns not matching factory shop manual, page5-65?
    Sent from my XT1080 using Tapatalk
  2. Terry Smith
    I faced that same puzzle reassembling my bike a few months back. All four funnels are identical, so it does not matter which way around they are installed.
  3. TOE CUTTER
    I do respect a man that pick's up on the fine points of a job and has a sense of panic. Most do not.
  4. RVFR
    Interesting I'm not the only one that thought Hmm.., in the process of installing the PC3 I needed to get the air box outa the way, hence therefore those stacks needed to come off, I didn't think about if they needed to go back a certain way as they're all the same, all though I did put the markings heading the same way ;)
  5. H0ki3
    H0ki3 New Member
    VA
    I had mine apart recently replacing thermostat hoses and was scratching my head when I got to the airbox. I finally realized there was no way to align the funnels the way the manual states. Thanks for putting me at ease haha. Only a honda would have little marks to align identical pieces of plastic haha, working on the VFR is a hoot. Honda knows how to make an easy bike to work on :)
  6. toadsear
    toadsear New Member
    Thank you, your right
  7. toadsear
    toadsear New Member
    Thy are the same part no. Think you just need to align one mark each but i don't understand why slot on bottom does not line up with anything.
