Air filter
Discussion in '6th Generation 2002-2013' started by Mark13, Feb 29, 2020.
  1. Mark13
    Mark13 New Member
    Glossop
    Simple
    Pipercross
    Or K&N
  2. Thumbs
    Thumbs Member
    Bath(ish)
    Pipercross
  3. hondaman219
    hondaman219 New Member
    maine usa
    Simple
    Oem.... you won't notice any gains with those filters . Some aftermarket filters claim to flow more but actually filter less. Why do all manufacturers use paper filters? If they made even a small difference they would be stock on high performance machines. Engineers spent lots of time developing filters and airbox. It's hard to do better. Stock filters last thousands of miles and are cheap to replace. I have been an auto tech for 30+ years. Just my 2 cents.
    BTW nitrogen in your tank will make you much faster
    jstehman likes this.
  4. Mark13
    Mark13 New Member
    Glossop
    Not to concerned about speed thinking more for better air flow the oem filters are gash a paper block would do a better job
  5. Mark13
    Mark13 New Member
    Glossop
    Came with K&N but I've always rated pipercross more in my cars anyway.
  6. NorcalBoy
    If you put them all in a vacuum box and test them for airflow, the stock filter actually flows better than you might expect. Did a test of all the available filters in 2008 using this method, the BMC Race was the best (as far as air flow), followed closely by a new oem filter.
    All filters were new, and prepped according to the manufacturers specs.
    OEM
    BMC Std
    BMC Race
    Pipercross
    K&N
    hondaman219 likes this.
  7. hondaman219
    maine usa
  8. Mark13
    Mark13 New Member
    Glossop
    I have used all types in the past oem aftermarket panels like paper type and K&N and pipercross (I my cars) and always felt pipercross perform the best never failed on me and in my cars I believe I've always noticed extra in performance.
  9. hondaman219
    maine usa
    Sounds like you have made up your mind. Plenty of people use them. Just not for me.
  10. Mark13
    Mark13 New Member
    Glossop
    Pretty much had yes just after others opinions on them 2 as I have 1 of each of them
