Air In Clutch Cylinder System.
Discussion in '1st & 2nd Generation 1983-1989' started by Martman, Sep 29, 2013.
  1. Martman
    Martman New Member
    Regina, Saskatchewan
    My 84 VF750F clutch and tranny seem to work well for about 30 miles, then I loose my clutch and have no movement. If I crack the slave bleed screw for a second I have full clutch and movement again. Same thing happens if I leave it over night once it cools down I seem to have full clutch again. When it is all working it seems to be fine with no clutch slip. I have bleed the slave 4 times and seems well until it gets hot. Anybody else have this problem. Even if my clutch is worn it should not affect my slave cylinder should it?
    Get rebuild seal kits for both mc and slave, and replace seals after a proper cleaning.
  3. Lobotomy
    Lobotomy New Member
    Toronto Ontario
    I just rebuilt my master and slave and things worked a lot better,
    problem is that it showed me how bad my clutch is, so I now have
    new clutch parts on order. I ordered the m/c and slave cylinder kits
    form V4 Marketplace and had them just inside a week. Both were easy
    to rebuild.
