All mods finished.
Discussion in '8th Generation 2014-Present' started by buck66m, Sep 28, 2018.
  1. buck66m
    buck66m New Member
    Since purchasing my 2017 Honda VFR800F I've done a few mods to her:
    - Delkevic 225mm slip on.
    - tinted double bubble screen.
    - headlight protectors.
    - Helibar rises.
    - Spy 5000m alarm.
    - Innovv-k2.
    - Ventura rack.
    - duel USB with volt meter.
    - K&N air filter.
    - removed snorkel.
    - Kaoko throttle lock.
    - custom designed tank pad.
    - RAM mounts for phone and gopro.
    - I modified the number plate holder to make it smaller.
    Mods that I'm thinking about doing:
    - PAIR valve.
    - reflective rim tape.
    - further modification to the number plate holder.
    All in all, I'm very happy with her transformation.
    flya750, GatorGreg, Viffer J and 2 others like this.
  2. duccmann
    Love where you mounted that camera.
    buck66m likes this.
  3. buck66m
    buck66m New Member
    It's a good position for it, takes great clips.
  4. GatorGreg
    GatorGreg Honda Fanboy/LitiGator
    Orlando
    Very nice! Where did you get the headlight protectors?
    buck66m likes this.
  5. buck66m
    buck66m New Member
  6. GatorGreg
    Orlando
    Thanks - were they easy to install? I’ve read our headlights are outrageously expensive to replace so me thinks it would be a wise investment to get those protectors.
    buck66m likes this.
  7. buck66m
    buck66m New Member
    Yeah, piss easy. They're held on by 4 velcro tabs per protector. If you look at the pic of the front of my bike, you can see the clear velcro tabs.
  8. ottablue
    ottablue New Member
    very nice set up!!! did you install rear camera...if so do you have any photos of the install? I am in the process installing innov cams the front will go where yours did but the rear still in question. Thanks.
    buck66m likes this.
  9. buck66m
    buck66m New Member
    I attached the rear camera to one of the number plate bolts.
  10. buck66m
    buck66m New Member
    I'm not 100% happy with its location, so I'll probably move it up to the lip above the reflector. I just didn't want to drill holes if I didn't have to.
  11. ottablue
    ottablue New Member
    Thanks for lightning fast reply!!! that looks nice but where I live I need to hide the cam otherwise people will rip it off here in new york if they see cam while bike is parked on the street :( that brings me to another question as to you just modified the rear tail where license plate goes yourself or you bought some kind off rear end tidy up kit? thanks.
    buck66m likes this.
  12. buck66m
    buck66m New Member
    That sucks that people will steal your cameras. The modified tail, I did myself. I'll post some pics for you.
      File size:
      174 KB
      36
      File size:
      265.5 KB
      34
      File size:
      182.9 KB
      35
      File size:
      133.2 KB
      35
      File size:
      146.6 KB
      34
  13. ottablue
    ottablue New Member
    thank you for the very detailed photos will be very helpful while minimizing my rear plate holder. I am actually thinking to do what you did but where you have red reflector strip cut hole in the reflector in the center and place camera there!!! make camera inconspicuous.
    buck66m likes this.
  14. buck66m
    buck66m New Member
    That sounds like a great place to mount it. I might look at doing the same thing.
  15. ottablue
    ottablue New Member
    Great. if you get to it earlier than me please post the photos of the install. I will do so once I get to it.
    buck66m likes this.
  16. buck66m
    buck66m New Member
    Not a prob mate.
  17. GatorGreg
    Orlando
    Excellent - thanks for the pic.
    buck66m likes this.
  18. buck66m
    buck66m New Member
    My pleasure mate. Happy to help out where I can.
  19. fink
    fink Member
    EE6F688D-1FA8-4CD0-8BFF-33C192AD9099.jpeg Nice set of mods. A real Eddie would have been much better.
    Looking into getting a set of innovos now after seeing you fb posts. Thanks
    You should maybe stick the dvr under the rear seat lock which would leave you loads of space.
  20. buck66m
    buck66m New Member
    Cheers mate. Over the next few days I'll be doing some changes to the position of the DVR and rear camera. I'll definitely look at moving the DVR to where you suggest.
