Any of you guys use this on your VFR?
Discussion in '6th Generation 2002-2013' started by VIFFER RIDER, Aug 24, 2009.
  1. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    I found something that might be of use for you VFR guys, a Project Kics Magnetic drain plug, they are $15 but i think its worth having since our bikes don't come with it from the factory.
    Has a pressed in flush mounted super strong rare earth magnet, it does not protrude like some of the cheapy ebay ones that may interfere with oil sump or perhaps something that moves near it. Made in Japan, made of lightweight AL7075 aluminum and comes with crush washer. I just put one on my VFR, it should help catch the metallic particles before it gets to the sump.
  2. mello dude
    Romania
    Well ok - where do I get one?
    MD
  3. VIFFER RIDER
    Socal
  4. drewl
    drewl Insider
    Virginia Beach, Va
    I have seen these used and sen debris stuck to them. Not sure on the actual data on engine wear though.
  5. deepdish
    deepdish Banned
    if the engine is broke in and oil has been changed as required, then there should not be any metal..??sounds like its for a new engine...
  6. VIFFER RIDER
    Socal
    Anything that wears is going to have small amounts of metal in it. Think about this, your engine and trans share the same oil. If you ever did a trans oil change on a car with a mag drain plug you will see that black dust, well with a bike you got engine and trans using the same oil.
  7. skimball
    skimball New Member
    KC
    I have not done the research on the composition of the VFR engine but on a lot of cars the magnetic drain plug is pretty useless as most of the engine is made of aluminum. That was the case on my Subie STI anyway.
  8. VIFFER RIDER
    Socal
    Yeah except that the engine case/heads doesn't move/wear/rotate like the iron/steel parts inside such as the gears, chains, bearings, crank, rods, cams, gearbox, etc etc. The only real thing non ferrous is like what just the block and heads? Those parts don't move or really wear which makes up very little of the debris if any.
  9. Kobe Diesel
    Kobe Diesel New Member
    CT
    Bearings are made of non-ferrous materials
  10. VIFFER RIDER
    Socal
    Just only the main crank and rod bearings, cams don't have bearings and the trans bearings are standard steel bearings.
  11. Kobe Diesel
    CT
    Yes, I should have been more specific, thanks for clarifying
  12. rodm850g
    rodm850g New Member
    Eastern,N.C.
    motor wear
    Guys,
    There is always oil analysis...I use "Blackstone Labs" they send you everything you need....new I didn't do one but as my vehicles get mileage on them I send in a sample ..its like $20 for a sample and gives you some heads up on what is wearing.....no it doesn't stop wear but you get a heads up if premature wear begins or if there is extra contaminants in your oil{ coolant}...YMMV but I value knowledge....
    Rodm850g
  13. Kobe Diesel
    CT
    Remeber, the oil analysis is only as good as the sample taken. Most labs throw out samples that have visible matter, b/c it eff's with the testing equipment. Run the bike around, go back home, draw a sample out with a CLEAN tube/hose and pump.
