any one who can help me
Discussion in '1st & 2nd Generation 1983-1989' started by tan.d.5, May 3, 2009.
  1. tan.d.5
    tan.d.5 New Member
    canada
    i have an 83 vf750f done afew things to get it running after it sat for a few years got it running the only proplem is ( onsaturday fired it up ) & it ony ran for around 10 mins a died had a good amount of gas init still.? if the thermosat has gone would this make the bike stop.? the bike would also not run again ( start up ) i put a new battery in it that day & it`s putting out good voltage. any ideasof what is going on all i wont to do is ride. thanks for your help & any replies you have
    Dave
  2. tjwor
    tjwor New Member
    Manhattan, KS
    will it turn over still and not start, or is it like the engine is seized?
  3. VifferDude
    VifferDude New Member
    Sydney Australia
    Did you put fresh fuel in it? Petrol goes bad after it's been sitting for long periods of time
  4. TOE CUTTER
    not enough
    Need more information to be of help.
  5. tan.d.5
    tan.d.5 New Member
    canada
    toecutter what else do you need to know..? this is what i have done so far cleaned carbs but havenot done any thing to them ( ajusted ) all stock new oil, spark plugs & leads, gas is only about 3 months old. this bike runs like she did when i first got her but as i said runs about 10 mins then she just stops then hard to restart ( when warm) also changed the theromstat. hope this helps...thanks...Dave
  6. TOE CUTTER
    Fuel
    Neckutters bike just had an issue like this and was bad fuel pump,would run fine until pump got hot. Had spare in attic and problem solved. Had one a couple of years ago with junk in bowl screens and would run for a short time and die , but would restart after sitting for a few minutes. The tank was clean but bugs were in fuel system and plugged it up . Tank had sat open at some time . You need to dtermine if it is fuel and check relay operation , fuel pump operation and delivery to carbs and possibly bowl screens as they may have been plugged when new fuel was sent down lines.
  7. squirrelman
    Like he said, check fuel tank for rust and maybe replace main fuel filter if it is clogged.
    An easy check is to open the float bowl drain screws and look for rust dust there.
    Pulse generators (aka, pick-up coils) will sometimes be OK when cold but fail as soon as engine reaches temperature.
  8. Craig in Alabama
    Craig in Alabama New Member
    Madison, AL
    It could also possibly be a clogged or obstructed tank vent hose.
    Craig :smile:
  9. tan.d.5
    tan.d.5 New Member
    canada
    thanks to all for all your help.
  10. deepdish
    deepdish Banned
    add slick50 everything be ok
  11. TOE CUTTER
    fuel cap
    I dont know if this an issue where you are at but in California our gas caps are not vented and the tanks are and out of state tanks are vented through the cap. Non vented gas cap on non vented tank will cause the bike to stop running after enough fuel is pumped out of it, when cap is opened you can hear the air rush in if that is the problem.
