Any reason not to remove it
Discussion in 'Mechanics Garage' started by NormK, Nov 15, 2014.
  1. NormK
    NormK New Member
    Is there any particular reason for the inverted "V" on the rear of the left side footpeg of an 86 750 (not sure how many models it is on) is it mainly to prevent your heel hitting the chain guard, I can't see any other reason, I want to remove it because it is up against my relocated rec/reg so it can get a bit of air flow over it
  2. NormK
    NormK New Member
    Ok obviously nobody has any thoughts on this so I will just cut it off
  3. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Whatever you do, DO NOT cut it off.
    Oh, never mind....
  4. NormK
    NormK New Member
    I can weld it back on :biggrin-new:
  5. ridervfr
    it might be one of those thoughful Honda-think touches where you can tie off a bungee cord? Do they call "it" a bungee Down Under??
  6. NormK
    NormK New Member
    bungee is good enough down here, but if that was its intended purpose wouldn't they have put one on the other side as well
  7. ridervfr
    My experience is with Gen 3 bikes, they have these "V" things on either side of my p foot pillion foot rests that I use for tying on a bungee. Without a picture, it makes it a little more difficult. I noticed on my bikes that they have holes on the pillion foot brackets where you could possibly tie in saddle bag rig or a top case.
    I cut off a bracket on another bike in order to mount a aftermarket shock that had a resevoir. Cheers, don't knock off any kangaroos ok...:thumbsup:
  8. derstuka
    San Diego, CA
    Are we talking about your penis again Norm?
  9. ridervfr
    John Wayne Bobbit of OZ>?
  10. 74ullc
    74ullc New Member
    Gulf Coast, Texas
  11. Grumpy old man
    Grumpy old man New Member
    New Zealand
    Cambridge, New Zealand
    Totally a token heel guard to keep boots off Chain guard/ swingarm
  12. NormK
    NormK New Member
    A couple of interesting replys there and obviously a bit like my penis these days, just a token how can you cut off something you can no longer find :playful:
  13. 74ullc
    74ullc New Member
    Gulf Coast, Texas
    Should I have turned the pic upside down for you considering your location? :cool-new:
    Speaking of penisuses....down under I guess they don't hang down huh? They always point up? Same for boobies? No saggy boobies down there, just some perkier than others. This thread sure went south in a hurry.
