Anyone fitted linear fork springs to 8th gen?
Discussion in '8th Generation 2014-Present' started by Thumbs, Aug 1, 2024.
  1. Thumbs
    Thumbs Member
    Bath(ish)
    I’m about to refresh the front end and while I have the forks apart was wondering about changing the springs from progressive to linear fork springs, any observations welcome
    Imo, the correct* linear springs are superior to progressive for sporting applications. Pretty damn sure most suspension gurus/experts agree.
    If you are mostly just cruising the main roads and highways... I'm sure progressive springs are just fine and a decent improvement over the woefully soft stock springs.
    Good valving obviously plays a very important part in an overall package improvement.
    *for honest rider+bike weight and claimed riding style
  3. Terry Smith
    I am also a big fan of using the "correct" springs at the front. Usually you end up with less preload to get the desired ride height, which make for a more supple ride. +1 on upgrading the valving as well, I have had great results with Racetech Gold Valves although their "base" settings tend to be a little firm for the rough roads here.
  4. Thumbs
    Thumbs Member
    Bath(ish)
    So nobody has actually done it, just the usual advice I already knew
    The actual bike doesn't really matter. While the 8th Gen is cool, there's nothing special about it that would make the advice or outcome different.
    If you like cornering, which is why you bought a sport bike I hope, then linear springs suited to your weight is the better option.
    NorcalBoy likes this.
  6. Terry Smith
    Well said Mike.
