Anyone use vinyl wrap?
Discussion in '1st & 2nd Generation 1983-1989' started by 4a15, Apr 28, 2013.
  1. 4a15
    4a15 New Member
    Cincinnati
    I've been checking out the vinyl wraps, especially the carbon fiber looking stuff to wrap all my bodywork in. From what i found it comes off without damaging paint, and its not too expensive.
    Its not going to add much weight... cosmetic only, although I'm sure it may add a few hidden horsepower somewhere.
    Anyone have any experience with this stuff. They claim it is removable, but i don't want it pealing off as I'm riding down the highway.
  2. 34468 Randy
    Basically the graphics on my bike are vinyl wrap. They have been on for over a year now. The pointed corners had to be trimmed round because they tended to peel back but they were trimmed back to about a 1/8 inch radius corner and all is good. This is the same stuff that the commercial marking on cars and truck are. You will need a heat gun to apply it to any compound curved surface though. I have peeled it off cars without removing any paint. Peeling it off painted plastic might be a different story though. I would suggest use heat when you are removing it to loosen the glue first.
    And yes, my graphics gave me at least 20 more hp.
  3. reg71
    Sikeston, MO
    someone did a thread talking about it. It was a 7th gen bike so it may be in that area. He covered his entire bike with it. Actually, I have seen several threads about doing it on here.
  4. 911mike
    911mike New Member
    Michigan
    I wrap vehicles for a living. Find a 3M certified installer and use 3M DI-NOC film. it comes in White carbon and black carbon. It's a little more espensive BUT it installs better than any of the other manufactures (Avery, Oracal, Mactac).
    Here is a link to find a installer -http://solutions.3m.com/wps/portal/3M/en_US/Graphics/3Mgraphics/ToolsAndSupport/Installers/
    A GOOD sign shop that installs wraps can do it too but do your research o them first. If they use 3M products its a pretty good indicator they know what there doing.
    The great part is it you get bored of it you can remove it in leas then 30 minutes with a little heat from a heat gun.
  5. Badbilly
    Christmas wrap is real cheap at Walmart right after Santa rides off on his Harley.
